Saw video thread
8:01 AM
The cooler things run, the longer they will last.
Keep your muff vented, your chain sharp, and your tune a bit rich and your saw will last much longer than the next guys. I also like to give em brakes by rotating what I'm using (when I can). It is also easier to fill 3 or 4 saws at once, instead of the same one over & over.
T.Roller
8:01 AM
Southeast, TN
I just run em. Whatever I have there in the size I need gets ran till I'm done
jmssaws
Banneded
7:01 AM
Temperature drops very quickly. Less than a minute and it wouldn't melt the 400° temp stick.
I use a front outlet since it's the most direct way out.
I was checking it immediately after cutting,as fast as I could and was getting 375 to 400 and in a matter of a few seconds it would cool 200 degrees.
mdavlee
Hillbilly grinder
8:01 AM
TN
I checked as the saw fell to the ground after a 5.5-7 minute cut. I had the chain right where all I had to do was hold the throttle so no stopping to slap a wedge in. I usually get a break and refill after every single cut milling. Touching up the chain every other or 3rd cut.
8:01 AM
What temp should one be looking for on the muffler with IR thermometer to start worrying about scoring going on inside?
Clutch bluing and plastic melt I solve that by running sharp chains.
First thing you should do is learn to sharpen when new at this. It's a good skill and can be done quickly as you get better at it. Make sure you are able to do it on site / in the woods. I take two chains for each saw and 2 or 3 saws the second chain is for total chain failure,. Multiple saws so you can stop once if sharpening needed. It's the 2 or 3 saw plan so you can have a productive day cutting.
If you can't sharpen then you have to take many more chains when doing yard trees!
Sent from my XT1585 using Tapatalk
I noticed a lot of huskys have plastic melt, I blame it on poor exhaust outlet aiming at plastic. A muff mod fixes this
