Saw for 28 inch bar
CR888
1:11 PM
I like roughly 25cc's for every 8 inches of bar length. 50cc=16"b/c, 75cc=24"b/c, 100cc=32"b/c. I cut Ozy hardwoods, but if you stay close to that formula you'll rarely ever wish you had more saw. It really depends on your conditions though, some guys happily run a 28" b/c on a 60cc saw in softwoods.
Nutball
10:11 PM
Mt. Juliet, TN
My findings are similar: 90cc-28", 75cc-24", 60cc 20" when using non low profile full comp chain, those combos will not leave you begging for more power when buried in hard wood.
90cc can run 32", 75cc can run 28", 60cc can run 24" but that's pushing it power wise and oiler wise for a stock saw in hardwood, you'd just about feel like you have a scaled up poulan.
andyshine77
11:11 PM
Cincinnati, OH
I used to buy into that, but found the 4" between a 24" bar and a 28" doesn't amount to a hill of beans if you keep you chain in good shape. A mm helps too. Maybe in Australian hardwood it will make a little differance, but not anything we have in the US. I believe it's more of a perception thing.[emoji111]
ammoaddict
11:11 PM
Granite Falls, NC
Is skip tooth chain an option? I like skip tooth on longer bars in hardwoods.
I like skip chain for noodling. It makes some long noodles. I made some and used them for kindling to build a campfire so my grandkids could make smores.
Sent from my Moto G (4) using Tapatalk
Wood Doctor
Edwin
10:11 PM
Omaha, Nebraska
Four of my saws are just right for pulling a 28" bar and chain:
(1) Stihl 046 Mag
(2) Makita 6401
(3) Echo CS-670
(4) McCulloch 610 and 5700 (Gasp! Yes, they can do it.)
My bigger saws can also do it but that adds more weight. I might have added yet another to the list: My Poulan 400o, but I have never tried that saw, and it's probably growling at me right now because I have not asked it to try.
mettee
8:11 PM
Arizona
I love the way this one runs...
11:11 PM
I like full comp on a 28” and under bar. Semi skip or full skip on a 32” bar and up mostly for the reason of less teeth to file cause I’m lazy.
Nutball
10:11 PM
Mt. Juliet, TN
Now I really gotta try a 7900 after seeing the reviews!
5 Star
"This saw is a beast it dont even cut the tree it rips it straight out of the ground has a hole 79cc of beast. I use it for everything making precise cuts for cabinet making, i even use it to pop open my beer fresh out of my new yeti cooler wink wink. So sharp it cuts threw anything wood, metals, concrete, and about you can think of. Would i recommend? yes i cousin brother billy bob done bought 2 for Halloween decorations cause there so scary hearing that 79cc of BEAST. HOPE I WIN YALLS YETI GIVEAWAY!!!!!!"
andyshine77
11:11 PM
Cincinnati, OH
5 Star
I've used mine for stump grinding, the saw is made so well the chain never gets dull.[emoji90]
