wcorey
- 2:01 PM
- Dec 11, 2015
- ma usa
Ok, I'm at least home from work and can focus a little more clearly on this.
As to bar mounts and pitches, what I've got covered is pretty much anything that will bolt up to
do25 (stihl), doo9 (lg husky) or ko95 (sm husky) mounts in 3/8, 3/8lp or .325.
A lot of latitude here since I'm blocking off the oiler holes and using m'cycle chain lube to keep the mess to a minimum.
So there are a lot of saws that will mount up directly with a few various stud spacers and without the need to line up lube ports.
I have two 35 pin rims, one in .325 and one that will handle both regular 3/8 and also 3/8lp. They slide on/off the driveshaft and are retained with an 'E' clip.
All three drive chains interchange on two bars, one a ko95 and the other a d009 milled out to d025 slot width.
Each bar has two sets of mounting holes depending on which rim is being used, both rims are the same pin count so the 3/8 is obviously larger dia.
Three screws on the bar, possible chain swap and the clip is basically all it takes to change from one setup to another.
Since the rims are so large, the chain wouldn't clear the clutch cover on many saws unless the saw was mounted 2 or more feet back from the driveshaft.
To deal with this I added an idler/tensioner wheel that is sprung vertically and adjusts horizontally on a t slot.
Most saws can be installed on the bar regardless of where the saws chain tensioner post is adjusted to and the idler wheel is then positioned to take up the slack.
