Saw builds
RI Chevy
1:05 PM
earth
You gotta check and see if it squats when it pees. Lol
hseII
Heef
1:05 PM
West Georgia
So what about a bubble top 066?
Would that be an acceptable candidate?
jmssaws
Banneded
12:05 PM
It has the big cases.
A aluminum flywheel saw can be stronger than the poly.
The tight cases make a difference
PA Dan
FYD
1:05 PM
White Oak PA
Ok so then I have to check my parts...I have what came to me as a parts saw but was completely and together. It has a bubble top and decomp cylinder. It has a poly flywheel but has the short case!
jmssaws
Banneded
12:05 PM
So it takes a square top 066 w/ an aluminum flywheel?
I take it all Bubble top 066 had the Poly Flywheel
Got It.
It doesn't have to be a old flat top to be strong,you can put a good cylinder on a 660 and help it but if you want one as strong as it can be then you need a old short case saw and a good cylinder.
064 or a early 066 will be the strongest
jmssaws
Banneded
12:05 PM
Only way it can be that way is from machine work.
The flywheel side case is different between the two
PA Dan
FYD
1:05 PM
White Oak PA
I may be in need of some parts then! Ugh!
1:05 PM
very thick base on the cylinder there
PA Dan
FYD
1:05 PM
White Oak PA
The saw came to me as a complete saw with a scored piston, busted recoil and cracked clutch cover. I know I took the flywheel of of the saw. This was sometime last fall so I don't remember exactly how it came apart. I don't remember anything unusual? Jay I sent you a picture of the inside of that jug last year before Christmas when we were talking 066's. Can't seem to find it now.
