Saw builds
Hedgerow
8:18 AM
I just bought a new WJ-10 for the 064.
I am disappointed I can't get the Bing 49 fixed up but a WJ is going to a lot easier to get parts for going forward.
I also want to get it running with a period model carb.
I also want to keep the 064 as an 85cc so I doubt it will struggle to supply fuel.
Now..... @Hedgerow
What is your thinking behind the change of intake from 78 to 76?
Not questioning you at all..... I want to learn from you guys and its the "why" in the journey that interests me as much and having a red hot saw.
More degrees of case compression.
Better fuel economy.
More efficient pump at lower rpm's.
jmssaws
Banneded
8:18 AM
I'm building dd a 066 today and while I have a wheel on it I checked 3 cylinders I just recently got. I double and triple checked my setup and it's right.
One is a ks one is a mahle decomp and the other is a mahle no decomp off a 066 i got back in the winter that has a bearing out.
There the best stock timed cylinders I've ever seen.
jmssaws
Banneded
8:18 AM
If it was easy, Girl Scouts would be doing it.
That saw you have in the video pulling the mike Lee 50" is impressive.
It seems you've got the 1122s figured out.
That saw is much stronger now and so are the new ones I'm building but did you see the video of my 394 with a 50" in the same log?
