Saw builds
junkman
Crush it
11:20 AM
pacific northwest
Did you check the metal flange between the carb and boot ,they are common to crack there .
Mattyo
Youtube speciawist
2:20 PM
Farmington, CT
Run it....or toss this brandy new cylinder?
Was doing the transfers and it just kept flaking :(
jmssaws
Banneded
1:20 PM
I've had lots of ks cylinders chip grinding with a double cut burr so I only use single cut or if it don't need a bunch of material moved a stone will not chip.
What kind of burr are you using.
Mattyo
Youtube speciawist
2:20 PM
Farmington, CT
I have polishers too that I use for finish up....but good point on the stone ...I'll hit it with a stone later....at the office now
Mattyo
Youtube speciawist
2:20 PM
Farmington, CT
I may go back to diamond. I don't know if single cut burrs exist in this particular size.
Mattyo
Youtube speciawist
2:20 PM
Farmington, CT
Would u run it? Or should I toss at this point?
Haven't done the rest of the port work....don't want to do it if it's junk
jmssaws
Banneded
1:20 PM
jmssaws
Banneded
1:20 PM
Racers do that for cookie cuts ,bad for a working saw ,i would add weight on a work saw .
I like the flush mount pull handle ,cleans up the look of the left side .
I've not noticed any loss in cut power from a light flywheel,usually just gains buy I've never tried one this light.
It was a broke flywheel so I done that,useless the way it was.
I hate the handle in a husky, always in the way tuning so I cut the damn thing off shorter
junkman
Crush it
11:20 AM
pacific northwest
It may run hotter without the extra cooling fins ,i only run longer bars so what i like in a saw is different than a lot of the rh coast likes .
Kind of like putting a cr250 flywheel and ignition in a 250r quad ,it will rev quicker ,but break the tires loose easier but loosing tourque for tire hook up ,a saw chain has to hook up in softwoods to cut fast ,maybe opposite of the hardwoods in the east ?
