Saw builds
Jchin
10:56 AM
Warwick, RI
My 066 still isn't fixed. Every peice new and still leaking.
I don't drink but I'm bout to get me a flat bottle
Jason, Take a deep breath and walk way from your trouble 066. Work on something else. I know it's hot and humid at your part of the country. Go get a cold drink and relax at little. You will find the solution to your problem. Chill a little......
Chainsaw Jim
Con Artist LLC
7:56 AM
Springfield Oregon
I'm assuming you switched plugs and checked torque on the decomp if it has one? After all the troubleshooting it seems like case gasket problem or case bolt coming loose.
jmssaws
Banneded
9:56 AM
Can you use a little bit of silicone to make it stop leaking?
Tried that too.
I'm on to it now though,I check 3 other saws that are fine and I can kill all of them spraying through the adjustment screw hole so the carb must be sucking it in somehow,not sure how but 4 saws wouldn't have the same problem.
So I guess I'm still looking for my problem.
Chris Zautner
10:56 AM
New York
Well that's a bummer. Walk away for a while and work on one of dem huskys. I'm really intrested to hear your report on the modified flywheel! Of course videos are a must.
Mattyo
Youtube speciawist
10:56 AM
Farmington, CT
20160714_211345.jpg is this a better photo?
It looks like it has more cracks and will keep peeling. Tear it back...smooth it up and run it? Or toss??
jmssaws
Banneded
9:56 AM
It won't tear anything major up,on my saw I'd run it awhile.
Raise the exhaust and transfers a mile and when it runs bad throw it in the trash. Be good practice
CR888
12:56 AM
Australia
I've had lots of ks cylinders chip grinding with a double cut burr so I only use single cut or if it didn't need a bunch of material moved a stone will not chip.
What kind of burr are you using.
A good tip for someone starting to port cylinders. I'd rather work this out reading a post than through personal experience on a nice saw. Is 'control' the benefit of a double cut burr?
Mattyo
Youtube speciawist
10:56 AM
Farmington, CT
this is the first cylinder I've had do this...and I've done probably 30 or so.
what J is likely referring to are the right angle handpieces that most porters use... CC specialty or foredom etc. I'm using dental drills at 400k rpm :) carbide I was using is a single cut carbide, but cross cut... called a great white ultra. worked well on all the other cylinders, but this one is chipping. I can use diamond as well, which will be unlikely to chip.
jake wells
no longer here
9:56 AM
ky
do you port teeth also? it might help me east faster.
jmssaws
Banneded
9:56 AM
Lot of time chipping can be avoided but I use to have it happen some especially on ks 064 cylinders.
On a side note I think I finally fixed my 066. I changed the all the rubber again,both seals again,coil,plug and rebuilt the carb again. It tuned right for the first time and has the pop out the exhaust it did have so if it ain't fixed I still helped. I'm loading the video of me tuning it to 14000 and it staying there.
Chris Zautner
10:56 AM
New York
Yeah! Glad you got her fixed!
