Saw builds
11:55 PM
Look for a crack in the rubber lines. And put a zip tie on the ends where they go on the barbs maybe. My 7900 would run with the impulse line burned off. Something was wonky and I shut it off in time
jmssaws
Banneded
10:55 PM
This saw isn't terrible but somthin is wrong with it, it's down on power and acts silly,I'm sure it's a airleak. Maybe
Can of eather is fixing to tell me where
jmssaws
Banneded
10:55 PM
I can't find a airleak and I don't think I put 3 bad carbs on it but stranger things have happened.
jake wells
no longer here
10:55 PM
ky
i have seen tank vents cause some unusual problems have you checked that?
jmssaws
Banneded
10:55 PM
Tank vent is new.
Eather will find a airleak so I don't think it has one.
It tunes around 1 and 1 with every carb I've tried.
jake wells
no longer here
10:55 PM
ky
bad secondary winding in the coil causing it to run on primary start side of the coil. only seen that in 2 stroke mowers though
jmssaws
Banneded
10:55 PM
It's down on power and 1 out of every 5 times I check for a 4stroke it won't be there. Impossible to get a good solid idle,it's either fat or lean
jake wells
no longer here
10:55 PM
ky
that sounds like a leak to me start it and take the starter off and spray around the base.
jmssaws
Banneded
10:55 PM
Has to be a airleak at the carb,only place I didn't check
jmssaws
Banneded
10:55 PM
Even though I ain't found one I still think it's a airleak.
11:55 PM
Throttle shaft could be worn. My 670 was sucking air there
jake wells
no longer here
10:55 PM
ky
yeah but he put a new carb on it and it still had the problem.
