Saw builds
Deets066
AKA Deetsey
12:01 PM
hmm... maybe 102, 120, 78 for me then.... to combine everyones numbers hehe.
i'm on it!
When I port mine I'm goin to start at 102, probly won't end up there. Mine will be higher.
I like to run it before I get to my final numbers so I can see how or if it gains by making changes
mdavlee
Hillbilly grinder
12:01 PM
TN
Pipe saw?
Work saw for playing. I haven't tried it yet but that's where I'm going towards. Smaller saws run good with numbers like that with the same stroke.
paragonbuilder
12:01 PM
Norwich, CT
I checked my notes, I was pretty close by memory. 159/121/157 duration so 100.5/119.5/78.5 opening.
Shawn do you like to grind for flow like you did on the 066 Jason has on all your builds? Or is it saw and purpose dependent?
Mattyo
Youtube speciawist
12:01 PM
Farmington, CT
92 exhaust...not sure I have the guts to cut that much out. i'll stick w/ 100 118 78 for now... seems right
looking to cut w/ 36" bar. the saw is going to have but one use... making 1 cut per day lol :) mostly this thing will sit on my shelf and i'll run my 350's, but if I gotta use a 394.... well...ya know
paragonbuilder
12:01 PM
Norwich, CT
What saws have you gone there with Mike?
paragonbuilder
12:01 PM
Norwich, CT
Can't go wrong with those numbers Matt!
Mattyo
Youtube speciawist
12:01 PM
Farmington, CT
just putting seals in now, already had one invert on me, pulled it out and the spring had popped out, hate that....
srcarr52
12:01 PM
Iowa City
What was the exhaust after 040 from the chamber?
I can't remember what I cut from mine but the exhaust was 110.
I can calculate it. 0.040" out of the squish and 0.020" squish clearance should land a stock cylinder around 141 dur, or 109.5 opening.
No, I grind all cylinders similar to that.
jmssaws
Banneded
11:01 AM
I don't know if a all oem parts 066 can be made to beat a 394. I haven't done it anyway
paragonbuilder
12:01 PM
Norwich, CT
I'd like to understand durations and what that all means to a 2 stroke. I'll start a thread for that.
So Shawn, what is your take on case capacity and velocity? Lots of talk of it making power and the need to keep the case as tight as possible. But at least on the 066 it seems that it's irrelevant.
