Saw builds
paragonbuilder
2:26 AM
Norwich, CT
Both are at 14000 but his is turning more in the wood because I can kinda let mine self feed but his wants to scream so i cant keep from prying on it to kill some rpm.
Nice to see you making a strong saw doing it in a totally different way.
Raises some questions now...
paragonbuilder
2:26 AM
Norwich, CT
All this talk of case capacity and tight transfers for velocity, seems to be irrelevant. What really is making power?
jmssaws
Banneded
1:26 AM
Yeah...... Why?
I guess flow and direction will trump velocity at some point.
The saws I build using velocity are very close to these and take a 1/4 of the time to do. Lots of ways to get the same results.
I will say that my 066 that Shaun ported feels violent and the one I did is very smooth so mine feels way stronger but it's not. They feel completely different.
jmssaws
Banneded
1:26 AM
Either way makes power so which ever way you like the best I guess.
If you like grinding go with flow and direction but if you don't use velocity.
I think flow and direction makes a little bit more power. Maybe
paragonbuilder
2:26 AM
Norwich, CT
Does one way feel free'r than the other?
srcarr52
2:26 AM
Iowa City
I think the anger comes from the transfer port stagger I run. Yes, it does take a long time to make a cylinder that light.
jmssaws
Banneded
1:26 AM
That will be the difference between the two, mine open on the intake side first.
Mattyo
Youtube speciawist
2:26 AM
Farmington, CT
Anyone got good numbers for s 394?
Stock squish now is .050 with gasket. Gonna go mill off 30 thou from the case...then see where I am at for numbers. Don't need to cut squish....don't want to go crazy.
Cylinder had some transfer but it's quite clean now.
Here we go!
srcarr52
2:26 AM
Iowa City
I'd have to check my notes but I think most of my 394's ran good around 158-160 ex duration, around 18 degrees blowdown, intake 4 degrees below square. Someone can convert that to opening timing but I think in duration and relation to ex timing.
Deets066
AKA Deetsey
2:26 AM
99-117-78 or so
