Saw builds
Brewz
7:33 PM
Hunter Valley - Australia
Talked the owner of the 064 into using the OEM cylinder which is a very nice Hahle.
Measured 101/123/74 stock
Took about 20 out of the band and 15 off the base plus a gasket delete and ground it to 102/122/78
It had a limited coil so I cut a new key way and fitted an unlimited 660 coil.
New Meteor piston which I lightened to the same weight as OEM.
Fitted a Hardline to the handle.
Replaced crank seals.
Removed the baffle and dual ported the muffler and added screens (China muffler)
I cant wait to get it in some timber. Will try to this week
BuckthornBonnie
5:33 AM
Penn Yan, NY
Pretty easy to cut a new key way? Nice that the case accepted the 660 coil-- most I've come across had the 3-hole fw case and required the dogleg or 046 coil.
