Ryobi cover won’t come out
wesamswailem
7:11 AM
Egypt
Hi from Cairo , Egypt [emoji4]
I just bought a Ryobi RCS 5050 Can you pls support me as I can’t open the 2 bolts.
The bolt won’t come out of the pin as I have seen in tutorials
I need to dismantle the cover to be able to ship it home.
Thanks [emoji1374]
SimonHS
12:11 PM
Yorkshire, England
Is the the chain brake engaged? Push the chain brake lever towards the handle and it should release the cover.
wesamswailem
7:11 AM
Egypt
Hi
I did yes
The thing that I can’t understand is why the bolts come out of the screw [emoji2363]
7:11 AM
Hi
I did yes
Are you meaning the studs came out with the bolts you took loose?
wesamswailem
7:11 AM
Egypt
Am not sure what stud means, but if you mean the screws attached to the body, no both are not moving
The bolts are not free although both are completely loos
7:11 AM
Pull the brake flag back to release
Tension on the clutch.
Or do you mean the bar nuts will not come off the studs that screw into the case.
Your pic is hard to determine the issue.
wesamswailem
7:11 AM
Egypt
Yes sir both won’t come out from the stud and mine is a different model the break is not a part of the cover IMG_8626.jpg
7:11 AM
wesamswailem
7:11 AM
Egypt
I missed you answer
I see my reply only
wesamswailem
7:11 AM
Egypt
The issue is not yet came to the chain tension , the nut itself is not coming out to go the second step . Didn’t touch the plastic cover yet
kneedeepinsaws
5:11 AM
Oil Country
Take the wrench and twist it off, use some force. Talk about an odd factory misstep
kneedeepinsaws
5:11 AM
Oil Country
It’s gotta come off some how get a wrench in there and remove it with force
heimannm
6:11 AM
Dike, Iowa
From your photos it looks like the bar studs (bolts coming out of the saw) and maybe the bar nuts are stripped (threads damaged). Try pulling on the nut as you unscrew them to see if they will come off, then have a close look at the threads on the bar studs and in the bar nuts.
Mark
