Remington
67L36Driver
8:24 AM
Do a search on AS. I covered both styles of Remington check valves posted there.
Pictures may be gone. [emoji37]
fossil
9:24 AM
Ontario, Canada
Thanks Carl. I saw that work around with the Lombard valve.
Interesting that you noted that on your PL-7 all four recoil cover screw holes were Helicoiled. Mine are as well
67L36Driver
8:24 AM
Need help IDing this saw. Im pretty sure it a Remington. It appears wer the tag was is now missing. Thanks for the help in advance. View attachment 189938View attachment 189939View attachment 189940View attachment 189941View attachment 189942
Wards SL-55, 82cc. [emoji106]
I had a beater Wards in nearly as bad cosmetic shape. It was my favorite saw to run. Lots of grunt and hardly any more weight than a Homie SXL.
Sold it to a fellow to power a Lewis winch. [emoji22]
JohnnyBlade
JUST GONNA SEND IT
8:24 AM
Momence,IL
Thanks for the info. U dont have to have a sad face emoji. I know a guy with one if ur interested;)
JohnnyBlade
JUST GONNA SEND IT
8:24 AM
Momence,IL
@JohnnyBlade . I absolutely love mine, is very powerful and irritatingto my one neighbor. The Remington roller nose bar, is a dream to use. Not able to compare to much as it is only the second roller nose I have ever used.
Mike
Hey Mike, how the heck do u start that thing? Lol! Mine has so much compression its silly
msellers
6:24 AM
Nevada
I slowly pull it over till it builds pressure well. Then I set the throttle lock, and take a firm grasp. Lock the handle into my leg, and give it a yank like it owes me money. But mine might now be as heavy on compression, haven't put a gauge on it. Probably should do that, now that I think of it. Here is the instructions according to the decal on my saw.
Jimsz
9:24 AM
Walterboro sc
I picked up this SL4 this past weekend; starts , runs and cuts good. I need to recut grooves in the starter cup, will likely do 1/2 the original number, there are a bunch. There is a lot of play between the shaft and clutch bushing, bushing to needle bearing is good. Any suggestions, there is a lot of wobble in the clutch bell at idle but I guess there is none at speed when the clutch locks up. Leave it alone?
Jimsz
9:24 AM
Walterboro sc
This is the tool I made from an old circular saw blade. None of my Dremel burrs would cut the groove sides square like I wanted. The carbide tooth does a pretty good job.
msellers
6:24 AM
Nevada
Very nice, looks like it is working well from the picture. I do like the simple low tech options better myself.
Thanks for sharing this. Could come in handy for manycof us I do believe.
Mike
