Remington
67L36Driver
5:45 AM
My backyard.
rocketnorton
3:45 AM
surrey, bc, can
need ipl, or pics of pump side of carter carb. s770. not pullin fuel. also, any hints on getting it out w/o takin the whole mf apart...
TIA
67L36Driver
5:45 AM
The Carter ND, unlike the Tilly HL, has to come off to get to its works.
Take a 7/16" box end ignition wtench and grind to fit.
The Carter parts illustration is in with the Super 75A IPL.
Look for it on Chainsawr.com.
rocketnorton
3:45 AM
surrey, bc, can
thanks, carl. its apart & soakin. pretty simple carb. not seein a "check", unless the needle/seat [spring loaded] does that... not knowin how it pulls thru dry line, otherwise... we'll see tomorrow.
67L36Driver
5:45 AM
Diaphragms and gaskets are available from Sugar Creek Supply (Kansas City).
Joe Salva.
67L36Driver
5:45 AM
Also before you put it back in, shorten the the studs up to just the thickness of the flange plus nut.
rocketnorton
3:45 AM
surrey, bc, can
still not pumpin. prolly needs kit. is clean, diaphragms tight like drumheads, even after soak...
runnin on squirt.
p61 western
Ol Mudflap
3:45 AM
GFY
I hope someone can help me out, I was brought a Power Kraft 4.0 to fix. There was parts of the rings in the muffler, so it needs a piston cylinder and rings. I have got it most the way tore down but can't get the clutch off. Does anybody have a good trick to get the clutch off these saws? Thanks in advance. Mike
67L36Driver
5:45 AM
Punch and BFH, get mean. LH threads.
You are wasting your time btw. There almost no NOS pistons or cylinders out there.
p61 western
Ol Mudflap
3:45 AM
GFY
I will prolly just put in good used parts to make it run for the guy.It was his dads saw and just wants it to run.
KYsawman
6:45 AM
Gone Fishing
I just picked up a sl-5 logmaster, this weekend good shape but no spark. 22" roller nose with 7/16 pitch chain half gone but enough to cut for a while. will post pictures soon.
