Random Thought Of The Day
Likesaws
3:02 AM
South west. Virginia
Does anybody run a double ended milling bar with a Husky powerhead on one end and a Stihl powerhead on the other? Is it just sacrilegious? Does it not work for some reason I wouldn't understand? Or would it cause some type of singularity to form that would destroy the mill, the operator, and everything else within a quarter mile radius as soon as the bar nuts are tightened?
:grazy:
I think it would work the saws don’t really know who’s on the other end but they both would enjoy the help.
9:02 AM
Is there anything intelligent one can do with dull chainsaw files other than tossing them into the scrap bin? o_O
9:02 AM
I did not want to take it, neighbor forced it upon me - 2-stroke mix fuel of unknown mix ratio.
I added oil into the right bottle, the left bottle is how they both were.
I added oil to both bottles and emptied them into my generic supermarket wheedwhacker - it will burn it no problem.
I did not like the looks of what floated inside one of those bottles though - yuck! :confused:
I also got a bottle with "B&C oil" , it looked suspicions - something that is not oil was contaminating the content, possibly water.
I smeared it on some oak shelf boards, should protect against bugs.
Guy owns a Stihl 038AV, he wasn't able to buck up a 20"-ish log - I wonder in what condition that poor saw is.
He'll bring it over for me to sharpen his chain in a couple days.
Thought of the day:
Do not trust anyone when it comes to fuel mix for Your equipment!
legdelimber
3:02 AM
N.C.
They can be ground into various shapes and used as de-burring knives, scrapers, etc.
many years ago, I ground the ends of them to de-burr new recoil rope pulleys, etc.
Use the chain grinder wheel and form a convex radius on the end.
You may find it works better to make several different ones so as to fit various things.
Think of a drill bit point, except the cutting edge is curved inwards by the shape of the chain grinder wheel radius.
Vary your angles a bit and you get a set tools to fit most of the funny spots where you need them.
Examples?
Places where ropes have worn a sharp edge sometimes need a bit of attention.
The hole where fuel lines press into fuel tanks is often another sharp spot that can cause cracks or splits.
After having a new recoil pulley/sheave cut the rope, I made up several of these tools.
Those die cast metal ones were notorious for having burrs or hard corners in the rope hole.
The hole needs to have a smooth radius (not corners) or you'll have a rope failure after a while.
Almost looks like the knot failed when the rope comes out.
Don't ignore a plastic pulleys either! It just cuts/breaks the rope little slower.
9:02 AM
Wait a little longer, global warming is doing it already.
9:02 AM
I personally don't use PET bottles for fuel, don't really understand why other's do.
Those 0.5 liter Coke bottles got filled with moonshine.
Would be a shame to waste the containers, the fuel/oil mix only adds to the flavor. :p
I have seen You around on and off! :)
BTW, I am German. ;)
Cheers :beer-toast1:
