Marshy
WFO Cutting
8:10 AM
Mexico NY
Don't do it.. horses are stupid.
Nice looking garage you have there! :aplastao:
Stack higher!
I thought about adding some 12' boards on the sides to make it a stake rack trailer. :risas3:
beaglebriar
The Peanut Gallery
8:10 AM
Warren Center, PA
Something to ponder: Make the barn small....if it'll hold ten hay burners guess how many you're gonna end up with??
Not that it isn't done but I've never known anyone to use sonotubes for a pole barn. Do you plan to set the poles on top of the tube after it's filled or in it?
Marshy
WFO Cutting
8:10 AM
Mexico NY
And they're cardboard, they'll self clearance on bridge girders.
I prefer them to stay 12'! :risas3::risas3:
The idea is to pour a column in the tube and use a wet set bracket to hold the post on the top of the column. If you level all the tops of the columns with a transit you can build an entire wall on the ground in the brackets and then lift it at one time.
Here is a great explination on preping the tubes then setting the perma column brackets. Second one is building the walls and third is lifting the the walls. Jump to the third video if you just want to watch them lift the walls.
Marshy
WFO Cutting
8:10 AM
Mexico NY
Why not just concrete the poles in the ground. My dad and I did them like that for 9 years.
The post will rot and the column provides a larger bearing surface to soread the load. You can also use a bigfoot on the end on the column to prevent lift from ground heaving.
Mkinslow
7:10 AM
Tennessee
Gotcha. But I've never seen one rot or rotted. We've moved several buildings that people bought standing and hired us to dismantle and move. Pulled posts out of ground and knocked concrete off with sledgehammer and nothing was wrong with them. Couple of them had been standing for 18-20 years. But I can see where it could be a problem in different types of soil or something.
Marshy
WFO Cutting
8:10 AM
Mexico NY
I have sandy loam soil with a very high water table. Plus I plan to build a hay loft and that combined with the snow/structure load could be trouble for a normal post in ground structure. I'm basically guaranteed the post will last more than a lifetime.
Mkinslow
7:10 AM
Tennessee
I guess building codes are different for pole buildings in the great cold north? We just have to go 32" down and set them in concrete. I get the rot thing though.
I hear its 32"deep x 24" circumference here now. Used to be 24"x24"
Marshy
WFO Cutting
8:10 AM
Mexico NY
48" here and they do not want post encased in concrete. Plus I believe they want deeper if you have a tall structure. Not sure all of those details yet but will be finding out soon.
Mkinslow
7:10 AM
Tennessee
Yeah it's definitely a good idea in those circumstances. Should be around for a long,long time.
stihl_head1982
Here long time
8:10 AM
USA
This URL may answer your interest.
Marshy
WFO Cutting
8:10 AM
Mexico NY
