- 11:11 AM
- Jan 1, 2016
- Warren Center, PA
This is what I figured you were gonna do, just wasn't sure. It looks like a fantastic way to build.I prefer them to stay 12'!
The idea is to pour a column in the tube and use a wet set bracket to hold the post on the top of the column. If you level all the tops of the columns with a transit you can build an entire wall on the ground in the brackets and then lift it at one time.
Here is a great explination on preping the tubes then setting the perma column brackets. Second one is building the walls and third is lifting the the walls. Jump to the third video if you just want to watch them lift the walls.
Setting posts in concrete will cause them to rot faster,so I've been told. When I built the wife's barn I wrapped the posts with felt anywhere they would come in contact with concrete, including the floor in the center aisle/tack room.
Technically the tack room never actually has been enclosed but she likes it so I keep my mouth shut. [emoji1]
Stall floors for horses should be a stone base with rubber mats, not concrete.
