That truck would never legally haul 22 ton here
I do not know what 57 gravel is. Here is goes by size.Trying to get a price on 57 clean gravel for my garage build. Looking like around 45 tons or so.
What are you guys currently paying for this?
How many feet of road did that cover?
How far are you from the quarry? Costs a bunch to haul it any distance. There's a big one here in town where I live.Wow, I am getting quoted too high for sure then. Thanks!
![]() | #57 Granite Stone | (1/2" - 1" ) | $75.33 / ton (full load) $180.50 / ton (min load) |
That is the price at the quarry. It does not include the trucking. Do you have any steel mills around you? If the quarries are gouging you then call a mill and see what slag is running. We used to get it for freeWow, I am getting quoted too high for sure then. Thanks!
Of course it depends on size but I figure 18 cu/ft/ton. One ton cover 36 square ft at 6 inchesHow many feet of road did that cover?
I think there might be a bit of miscommunication due to differences to regions. I assumed you were asking about gravel....crushed limestone.It's a little over 10 miles away. I'm getting quoted too high for sure. I need to contact the quarry directly. I'm going to need at least two full dump trucks of gravel, if not three based on the weight.
Quote is 75.33 per ton on full truck of approximately 20ish tons. So, about $1,500.00 per truck, times three trucks.
I'm going to keep checking around.
How many feet of road did that cover?Of course it depends on size but I figure 18 cu/ft/ton. One ton cover 36 square ft at 6 inches
It is a simple math calculation.
A road 12ft wide by 300 ft long is 3600 square feet.
To calculate the cubic feet needed for a 6 inch base take 12 x 300 x 0.5 divided by 18. That equals 1800
Take 1800 divided by 18 and that is 100 ton. Of course there are MANY variables but that is rough guesstimate
What type of truck are they hauling it with to get 20 tons?It's a little over 10 miles away. I'm getting quoted too high for sure. I need to contact the quarry directly. I'm going to need at least two full dump trucks of gravel, if not three based on the weight.
Well 100 ton should cover a road 300 feet long that is 12 feet wide and cover it at a depth of 6 inches. Now that is rough numbers. If you are asking how much gravel you need to cover a specific road well then that is unanswerable. It is very much dependent on variables. It depends on the base, the size of the gravel, and the mix of screenings. Our roads here have a base that in some places just might be 3 to 4 feet deep. At the top of my hill........of my...... the base yeah maybe 6 inches.How many feet of road did that cover?
1"-3" clean is $15/ton
