Cerberus
Cerberus the aardvark, not the hell-hound!!
- 2:39 AM
- Jan 20, 2020
- Florida (tampa area)
I wanna be sure I understand / am approaching things correctly here...
This saw was a monster to start, now - w/o a plug firing while pulling that cord - now it lets you pull the cord like "a regular saw" and feels like one (well, if you'd pulled the wire from the spark-plug!)
My confusion/misunderstanding: I went diagnosing a no-spark situation, new plugs made no difference, ordered a coil & about to install it, but while diagnosing I attached my tachometer and pulled and, while it never gave a # of RPM's, it DID 'turn on' and show "0" a couple times! Have never ever seen this lil tachometer say "0"....I would *expect* zero, since I suspect the problem is dead-coil, but am confused how the tachometer can even "turn on" enough to tell me "0" if there's no spark/pulse? Maybe even a dead coil will yield some non-zero?
Thanks a ton for any help, TBH the coil system confounds me the most on a powersaw, how it "has power" to the plug despite no visible source of electrical power!
/Will update shortly on what my 'direct swap' of the coil did, it's almost funny because I realized I don't need it to turn-on to know the swap "did it", I simply need to try starting it and have it tell me "NOPE, try again weakling" like it does when the plug fires (w/o a plug firing, you can pull that cord nice & smoothly, but starting it -- going from 0 to 3k rpm by-hand -- has proven absurdly difficult for this small guy here!!)
