Preparing to port first saw - which one, and what method?
mainer_in_ak
12:14 AM
Interior Alaska
Put a big bar on it and see how it does.
No need, I run 20-24" on all my 60-67 cc fodder.
Nother 67 cc saw:
MS 400 without a base gasket and no port work:
100.5 degree exuahst roof. 122 and 126 on the transfers. With the lighter magnesium piston, it cuts about 1 second faster.
jacktheripper
Papa Squat
2:14 AM
Wyoming
OK, so I got to test it. With the transfers done it gained torque and speed. It is now 4-stroking at 14k, and pulling 11.5k in the cut. Throttle response is way snappier, and it sounds meaner too. Compression is at 170 plus here at 5500 feet, which converts to over 200psi at sea level. Totally psyko-ss-insan-o, baby!
jacktheripper
Papa Squat
2:14 AM
Wyoming
I’m a “bit” of a stranger to the model. What’s the current slug look like?
Like Mike CFB said, the numbers are only part of the puzzle. You have to physically look at what’s going on as well. How much of the lowers does the piston cover after the intake floor closes? Where will the crank weights be at that time? What’s the case/displacement ratio?
There’s a pretty good chance that the windowed slug is going to increase case volume and decrease crank compression pressure. This will make the saw a slug to recover when it’s dawged down in the cut.
A lot of the older husky’s have assymetric uppers from the factory. Were yours even?
Your port work looks nice. Exhaust roof symmetry is sometimes easier to check with a piston in the bore. The only thing I don’t love is how big your uppers look.
Thanks for commenting! I know that gains have been made from using the windowed piston instead of the full circle one. I guess this will result in a bit of trial and error. I did slope the lowers, which would add additional case volume. I just don't know if the windowed piston will put it over it's threshold. As for the uppers, I raised them to the same level. I know that the flywheel side was about a degree or so higher. My thought was that I would want more oil getting to the clutch side bearing, so I would even them out. I don't actually know if that's good reasoning.
MG porting
1:14 AM
Wa
I guess when you're cut wood that's only 20" across then yeah building something that seems 15,000rpm is fine.
mainer_in_ak
12:14 AM
Interior Alaska
Neighbor runs a 28" bar doing 18-20ft rip cuts. He's well over 10 gallons of mix on his 67 cc saw. 104 degree exuahst roof, 122 on the transfers, 180 psi.
He borrowed my 67 cc saw and used his 28" mill. He noticed faster cuts with my saw. Anyhow thanks for the lessons on torque.
jacktheripper
Papa Squat
2:14 AM
Wyoming
I threw the new windowed meteor piston in it. I can't really tell if it changed much. RPM's were nearly the same in the cut, maybe 200 faster? The kit came with the hard F cast rings, so maybe I'll see gains as it breaks in. Overall very satisfied, and now I just need to use it.
David Young
Safety First !!!!!!
4:14 AM
vt
The 266 will be the easiest, it needs the exhaust port worked over mostly, squish is good usually as well as timing and compression.
this is my pic too. if you mess up there are others out there everywhere. the 266 had a nice tight chamber. bgd, widen the exhaust and open up the muffler will help a good bit. the intake I would lower if the duration seemed low, you have to check it first.
common newb mistakes...
Don't hog out the lowers! just because you can doesn't mean you should
Port shape symmetry and gentle radius, chamfer the ports and then check for a smooth edge with your finger. use a piece of sand paper on your finger tip to smooth rough edges.
clean the cylinder with a petroleum based solvent. use an old toothbrush and scrub it like crazy. when you are done clean it again.
Once its dry spray a degreaser on a white paper towel. Purple power, zep purple, LA awesome, simple green. wipe the cylinder wall down. if there is any discoloration on the paper towel. clean it some more.
when done rinse with water, dry and coat with oil either a spray on oil or take mixing oil, motor oil, and coat inside the cylinder.
don't get greedy first go round.
Here for the Yum Yum Sauce
3:14 AM
Yes, 266 is already a good running saw, best medicine comes in small doses.
Just changing from the stock full circle piston to a windowed 268XP style piston gives it a boost in performance.
jacktheripper
Papa Squat
2:14 AM
Wyoming
Today I ran the newly ported 266 against my stock 272. This is the first saw video I've ever made. I always get frustrated when saw videos aren't done very well, and now I understand that I should have some mercy on those making the videos. My apologies for the poor quality. I will try to get a more scientific comparison using the same B+C. I should mention that both chains were nice and sharp, but the 266 chain had low rakers.
According to my watch, the ported 266 beats the 272 by about five seconds each time.
Here's also a pic of the full circle piston vs windowed meteor
jacktheripper
Papa Squat
2:14 AM
Wyoming
Last night I decided to tear my 272xp down, map the port timing, and port it, since the 266xp was so successful.
The numbers I have for it sans base gasket are as follows:
Ex: 105 (150 dur)
Tr: 125 (110 dur)
In: 73 (146 dur)
Squish: .020
I think I’ll bring it to:
Ex: 102 (156 dur)
Tr: 120 (120 dur)
In: 78 (156 dur)
We’ll see how it goes.
Since case volume is less in a 272 relative to the cylinder, are there any recommendations for port shape and size? Thanks!
jacktheripper
Papa Squat
2:14 AM
Wyoming
Making progress on the 272xp. I decided to do it all the right way. Base and squish cut with a buddy of mine. Took .040 out of the squish. Just did the upper transfers tonight too with his right angle handpiece. Took them up to 120.
jacktheripper
Papa Squat
2:14 AM
Wyoming
Testing tomorrow… heat cycled tonight. I can already tell the filter is choking it up. I need a better flowing filter option. It has the pleated HD filter now, but maybe the smaller mesh regular style filter will be better if I can get my hands on a setup. Timing is advanced and muffler is modded, but I also think not enough.
