- 4:37 PM
- Apr 5, 2024
- Wyoming
Hey everyone,
I have been around the forum almost daily for the last year, and I have been fixing, building, and restoring saws for longer. I have done a number of ground-up builds, small performance mods (muff mods, timing advances, base gasket deletes, carb mods, air filter mods, etc.). I have had a blast doing these stock-mod builds, but I am envious of the skill that many here have when it comes to port work. I initially wasn't too interested in ported saws, but an 034s from @drf256 changed my mind on that.
I have been acquiring knowledge and tools for porting my first saw, and I think I'm at the point where I'd like to try it. I don't have access to a lathe or machining tools, nor do I have a right angle grinder, so my first port job will likely be a pretty simple one.
I have this grinder, a full selection of double cut burrs, diamond balls, polishing mandrels, etc. I have a timing wheel on a drill chuck as well.
I have a few good stock candidates for porting: Husky 266 and 272, Stihl 024 and 038m. I have additional OEM cylinders for the 266, the 024, and the 038M in case I totally mess up.
Which should I start with first, and what numbers/shapes/etc should I be working with?
Thanks for the help.
