Clarkbug
- 11:45 AM
- Sep 19, 2022
- Northeast
Evening everyone.
I had posted over in the Poulan thread, but figured I would ask here in the general forum also. (sorry that its long winded, wanted to get as much info as might be helpful out there)
I picked up a PP295 for a few bucks at a flea market last fall, and recently tore into it. Other than being filthy, it clearly needed fuel lines and an air filter, and I assumed a carb kit. I put in a new fuel line, fuel filter, air filter, and a carb kit. The screen in the carb was filled with sawdust, and I put in a new needle from the kit. I didnt pull the welch plug, but wondering if I should have. Pulled the limiters off, and aside from having to turn both the H and L screws out more than expected, it fired up and ran pretty well I thought.
I used it for a few cuts, and put it away for the day. Next day went to go use it to try it out a bit more, and the idle was higher. I figured I just needed to adjust a little, and started fiddling, but after a few more cuts it seemed like I wasnt able to find a good spot for it to run and then it wanted to run away. So, my guess is that there was an air leak and I shut it down for more diagnosing.
Pulled it apart again tonight. Piston and cylinder look great, so doesnt appear to be any damage. From looking under the clutch, I am guessing someone has been here before me. There is black sealant thats a little sloppy on the clutch side, and I noticed some on the fins of the cylinder (figure that wouldnt be factory). The flywheel side doesnt look like there is any extra squeeze out at all. I did notice it has what just looks like a plastic seal, so I guess this is the two piece setup where I dont need to do bearings also.
Given the history of these kinda saws, and that someone looks to have been here, is it a pretty safe bet to just put seals in it? I did notice there is a cut along the bottom of the silicone intake boot for the pulse line, but it doesnt go all the way through. Cannot see where else there would be a chance to have a leak, unless its because I re-used the gasket between the carb and the metal plate that seals up against that boot.
Or, is there something that could be up with my carb rebuild that would make it hard to actually tune? I have usually started my screws about 1 1/2 turns out, and this was 3 1/2 to start.
Appreciate any insight before I just fire the parts cannon. (I know thats hard to do without being here and looking at it)
