Post up your ported cylinder Artwork
Canadian farm boy
“Normal” people scare me.
8:58 PM
Ontario, Canada
I'm new to this and basicly have a Dremel and home made attachments. It's better then expected for my own evaluation. It's a start.i have no idea what anybody else uses. I just know I cant afford it.
P.s. it's a 372XP big bore china thing. Cheap and useable. View attachment 233052
Looks good. Just make sure the exhaust port roof has some ark to it. It looks a little flat in the picture.
Canadian farm boy
8:58 PM
Ontario, Canada
@Canadian farm boy, mind sharing the stock numbers for that 5105?
Top notch work, man.
I actually didn’t time the cylinder until after I had done the machine work.
So with just a gasket delete (.036) the cylinder timed at
76/135/113
I Know Something
7:58 PM
Fairmont, Minnesota
I actually didn't touch anything but took the edge off of it. And thanks. I just enlarged it a bit was all. Still learning.
legdelimber
8:58 PM
N.C.
Picture is focused on the combustion chamber, so the flange area is a bit fuzzy of course and hard for my eyes to make out well.
It may just be the chamfer/bevel on the edge.
But is the spigot/extension a bit thin in a region on exhaust side?
How much does the cylinder rely on the spigot/extension to locate it in the cases?
Mattyo
Youtube speciawist
8:58 PM
Farmington, CT
Had to read the post twice to understand what you meant. It's a good question. I don't think the skirts are a press fit into the cases anyway so it's not like they do the exact positioning. Personally I think the bolt holes are pretty exact and line things up best. In addition I move the piston to bdc when I'm seating the head so that helps a bit to align the head. Maybe someone else can chime in here too. The skirt was nicked a bit by the bridgeport because I cut the base freehand. But even so ...I'm pretty sure there are spots of full thickness.
Oh and on top of that ...this is a 52mm china head. So the skirts are thin to begin with. As the head gets bored wider....the skirts get thinner.
8:58 PM
Looks like some real hack work. Nice job on the save.
Thanks David, I took a look at the piston when I got the saw and it was all scuffed up. I knew I needed to investigate further. Good thing I did! I feel good about the salvage of the cylinder and the saw runs good now. Should the owner have a problem I’ll find him a new cylinder.
MG porting
5:58 PM
Wa
Looks good like Canadian farm boy said give the roof of the exhaust some arch.
