Really need a builder case to port a jug. I even use a builder case when I have an entire saw, provide I have one. I do for most Stihl models. It enables me to not have to clean the jug between every grinding step and not scratch up the slug in the end use saw. But then again, to each their own.
Factory squish bands are rarely truly flat, so someone telling me factory squish is 40 doesn’t mean I can take 20 from the band and 40 from the base and be 20 squish. It will almost always be wrong.
I’ve been taking measurements of base to band depths of most models I have done. If you need those figures for a particular model, they can get you close. Just let me know.
Port height can be figured out fairly accurately by using the Torquesoft software for piston height vs degree. There is a more complicated program for figuring out intake floor etc... Maybe someone can chime in on that one. Sounds like “Berlinetta” of something like that, the name escapes me right now. Both are available free online.
The other issue will be “can” vs “will” someone do it. There are many reasons builders will not port a jug without doing the assembly. An undesired result may occur, and then the finger pointing starts as to who’s fault that is.
Just my $.02
