Nitehawk55
- 10:34 AM
- Dec 20, 2015
- Ontario
Fill it with JB weld and send it back ??
customer returned via ebay
Customer believes manufacturer defect
Stihl ms192t
What say you?
View attachment 33470 View attachment 33471 View attachment 33472
Yes metal piston stop...seen it more than one time.piston stop. Couldn't be much clearer
Well I have just got in from the garage. I used a Stihl piston stop tool, a 19mm impact socket and a 2ft breaker bar. All on a pattern TS400 piston. The most I could get was a mark on the piston top. Granted the TS400 is a concrete saw and the spark plug hole is straight above the piston. As opposed to offset. However I would have thought the strength of chainsaw and concrete saw components where similar.
I did have the bar cranked so hard I nearly ripped the saw body from the rubber vibration mounts. Still couldn't break the piston. Was tempted to try it with an impact wrench. However running a compressor this late would annoy the neighbours!
Did strike me that if someone used an auto motive bolt with a tapered end as opposed to a blunt end (proper tool). That would mark the same. If the £9 was to expensive for the real tool.
Seems a fair amount of force was used!!!!
Also unless I am missing something? If the piston failed under use why is there no carbon marking on the piston. Or was the really annoyed customer so mad he cleaned it before sending it back.
Anyway that my tuppence worth
Will update if I can kill the piston with an impact breaker.
He also thought you were too dumb to figure it out. You don't need *dipsticks like that for customers.It's great that you take that approach Dave...
He knows damn well what happened.
Stihl ms192t
What say you?
That person is an *a-hole! I have no time to read threads today. You should send it back to that person special delivery via his front window in the living room.
SD Jones![]()
Positive Feedback: Defective part they will not refund nor exchange
Buyer: Member id xxxxxx### ( Feedback Score Of 76)![]()
Stihl MS192T Chainsaw New OEM piston 1137-030-2002 37mm (#321738937464) US $27.00
ah I love my job/hobby![]()
