Adirondackstihl
- 5:34 AM
- Dec 4, 2015
- Upstate NY
If you look close, you can see indentations of tool marks from a lathe pressed in there.My guess was:
The guy said it only tan for a few minutes.
I showed it to parts manager and then it made its way around the dealership through parts and service.
I hadnt considered the piston stop because i use a plastic stop, but i can check the indentation on the stop as well
Definitely not a spark plug, but rather a metal piston stop.
That piston never saw compression. He knew he *f-worded up, the moment he *f-worded it up.
He used a big *f-worden wratchet to install the clutch........
That's how that went down
