lehman live edge slab
Live Action
- 11:14 PM
- Sep 2, 2017
- Mn
Don’t use diamond on regular chain, only stone or cbn wheels for steel chains and diamond for carbide tip
Do you have the dressing stone for the wheel ? You can adjust the shape a little for different results ,start with half round the shape of a file .A clogged / dirty wheel is bad also ,need to keep it dressed for a crisp edge on the tooth .Thanks for all the tips.
I don't understand why I'm having so much trouble getting a decent hook. I bought a 5/32 diamond grinding wheel because it seemed perfect for 325
I guess I have to use 1/4, then do a second pass to clean out the bottom portion?
I'm starting to question whether the grinding wheel is any faster then hand sharpening at this point!
Whut do you know about teef ?The chain in question here looks like it's ready for a 5/32 file in my humble experience.
Cut the bottom of the toof out a little so you can get some more hook on that cutter.
here are 3 examples i did a while back ,first is a slower chain ,less hook less top plate View attachment 187759View attachment 187760
this one has a little more hook and top plate angle to it so will cut a little faster
View attachment 187761 View attachment 187762
This one was pretty grabby ,so there is a limit of how much hook you want ,so you can tune the chain to the powerhead with some trial and error ,also when cutting in dirty wood ,the less top plate you run the stronger the outer corner will be so will stay sharp longer .View attachment 187764
