Paslode framer not firing
foragefarmer
70cc groupie
3:38 PM
Central, Va.
I thought it was the big O-ring having gone bad. So I got a rebuild kit that included O-ring, spark plug, etc.. Well it wasn't that. I replaced the spark plug. Battery is good. Green light is flashing. Fan comes on. New fuel cell. You can smell fuel.
Anyone have any ideas?
jakethesnake
I Am The Snake
3:38 PM
Here & Now
Can you tell if the wire to the plug is sending juice? That can happen periodically. Is the nose you push down on the lumber depressing fully? There is an adjustment there sometimes the head goes back enough Ty start the fan but not enough to allow it to fire Check those couple things Aggravating guns at times You might be able to push it down the edge of some lumber and shoot a nail as a miss. If that works the head needs to be adjusted I'll try to explain better if that makes no sense
jakethesnake
I Am The Snake
3:38 PM
Here & Now
It could be very close but not quite fully depressing. I'm not sure. If that doesn't fix I'd have to look into the trigger mechanism itself I've taken then in for repair before Don't use one a ton anymore they are nice when they work good They're "cordless"
foragefarmer
70cc groupie
3:38 PM
Central, Va.
I got it working but am not happy with the fix. I bent the lever with the roller enough to fully trip the switch when in the proper position.
Guido Salvage
Supreme saw hoeder
3:38 PM
Farmville, VA
Rob, you need any replacements? A number of them here in pawn shops.
jakethesnake
I Am The Snake
3:38 PM
Here & Now
Good job on gettin it to work they are handy as heck at times
