Wonkydonkey
Plastic member
- 2:41 PM
- May 14, 2017
- Sussex, UK.
Your hard nose bar only really cares about the drive link gauge, because it has no sprocket on it to dictate the chain pitch. , I’m guessing it’s 0.63 (1.6mm) gauge because you say it’s stamped 404.
However your clutch sprocket is now dictating what chain pitch needs to be used. So if you change the sprocket on the clutch to a 3/8 then I think your find a 36” bar is 114 DL.
(We don’t currently know what sprocket is on your saw, or what pitch chain your using)
what letters and or numbers are on the chain Dl ? if it’s Carlton then it should say, and you can use the chart I’ve added to work out and be sure what your current chain pitch & gauge is.
Sometime the clutch sprocket is not marked and the easiest way to work out what it is, is to have a known chain pitch and see if it fits.
