Old Dirty Feta and the MS500i--the Hi-Tech Wood Lobotomizer
qurotro
Cookie Cutter
12:09 PM
Ar
Grinding the exhaust port corners? Seems ot can be widen a bit without messing the timing.
AlfA01
8:09 PM
Evia, Greece
Let's strip this thing and see what's underneath it's skin....
A look down the inlet toward the cylinder. You can just make out the injector outlet just before the cylinder...
Two fuel tubes...fly side is input from the tank and the other is for the primer bulb.
AlfA01
8:09 PM
Evia, Greece
Here it is all disassembled. Well, to the short block at least.
This plastic flange hides the fourth screw that attaches the intake to the cylinder. Necessary to remove it first to remove the intake.
Also it provides the only clamping pressure for the intake boot.
Intake boot.
StephK87
7:09 PM
Germany
Same 25" B/C combo.
Before...
After...
i checked the cut times by fps
1. cut MS500i 8,56 sec
2. cut 79er 6,53 sec
second vid 500i muffler modded
1. cut MS500i 6,86 sec
2. cut MS500i 6,63 sec
about ~ 22% gain
how much break in time you had between the cuts?
AlfA01
8:09 PM
Evia, Greece
about ~ 22% gain
Awesome Steph. I appreciate you taking the time to check. There's only about 1/2 tank burned since the previous video. Decent gains for a minor mod. :)
AlfA01
8:09 PM
Evia, Greece
Cool...the cylinder build date and time stamp.
Time to look at some numbers...
Impossible to get the degree wheel set without pulling the flywheel. The generator in this thing has magnets about every 20* so the flywheel will only stay put in 20* increments.
Improvised a little flywheel puller.
StephK87
7:09 PM
Germany
Yes! I had the same experience [emoji28]
Gesendet von meinem SM-G965F mit Tapatalk
