Old Dirty Feta and the MS500i--the Hi-Tech Wood Lobotomizer
AlfA01
10:48 AM
Evia, Greece
It'll be interesting to see what the 3/4 or full-wrap handle looks like if they ever make one.
My money would be on something like the 462 wrap, JJ. The differences seem subtle, but enough of a difference to make modding a 462 wrap unlikely though.
mettee
12:48 AM
Arizona
it uses the acceleration of the crankshaft while the piston goes up/down to specify the correct ignition timing and the flywheel key is only for the first start up to get the engine running.
Yes!
AlfA01
10:48 AM
Evia, Greece
Nohoff said it only uses the flywheel for initial start up and after that it go’s by rpm for the timing slope if I remember correctly
From the way I see it on the saw, the only way RPM can be determined is by sensing position of the flywheel/crank. More than likely there is some confusion between the timing for spark with the timing for the injector.
Advancing the flywheel may also trigger the injector 6 or 8° too early....right into the face of the intake skirt lol
Won't dropping the cylinder potentially have the same effect, Kevin? I'm curious how the injector timing and the spark timing are separately determined. My brain goes directly to crank timing.
Offsetting the cylinder up/down, would change the port timing, which could cause the injector to potentially spray fuel at the incorrect time also.
In order to optimize port window availability, an adjustment in fuel delivery may be mandatory.
It doesn't seem possible that spark isn't directly relevant to crank position. I would agree that injector time can vary according to RPM.
The piston moving up and down in the cylinder isn't visibly metered by this saw. In other words there is no piston position sensor. The only way to determine RPM is via crank revolutions (i.e, RPM's).
I'd like to get my hands on Stihl's "theory of operation" files.
Skeans1
12:48 AM
Oregon
My money is on the 3/4 if they make one at all, ever wonder why they send over a 70cc saw out of the factory without a wrap and big dawgs?
Evansaw
10:48 AM
Greece
Especially considering how much a 500i is going to cost it should be thrown in for free :)
You are correct about the big retailing price and of course the huge demand in American markets for such wraps.
Other than guessing we can only think these might be available when the saw arrives there? Here in Europe they just don’t care
Skeans1
12:48 AM
Oregon
It’s not just a demand, places BC it’s a requirement for safety when falling timber.
Evansaw
10:48 AM
Greece
Only Stihl knows my friend when...
For them bureaucrats safety requirements is still another demand. And of course they know for years what customers and certain areas want.
Why it’s not ready yet who knows... believe it’s going together with saw release
