PAST Ohio Race GTG
Deets066
AKA Deetsey
7:45 PM
Mine's not a super or I'd cut and port the cylinder and bring it down for you
I finished the machining and port work anyway on this jug. Just left the top ring out.
But it's only 150 psi with .050 off the base
Deets066
AKA Deetsey
7:45 PM
That's a WJ 69 that I shoe horned in there too
7:45 PM
Just doesn't have any ass in the cut
42mm piston? Meteor only lists 024, not 024s. If they're both the same, could put your piston in my saw if you wanted. Idk. Maybe I can save the piston and port and run it. I'll give it a go tomorrow night.
What boot did you use?
Deets066
AKA Deetsey
7:45 PM
039 boot
Could be carb issues yet too, I cut the snorkel off the top of the carb. Which obviously leaves a big assed hole. How does this affect the carb
7:45 PM
039 boot
It let's sawdust into the diaphragm. There's already a small hole to allow it to vent. You made it bigger is all.
Mine has an HD16 I think on it from an 044. Wide open it tuned fine, but mixture is touchy at idle. Had to solder off half the hole in the butterfly to close off some air to get it to idle down
