wcorey
- 3:50 PM
- Dec 11, 2015
- ma usa
I thought @wcorey was working on something to cut the top out a little? His invention was pretty slick.
Point of this is that Al is sanding the band to closely match the radius of the piston dome rather than simply cutting it angled but at a straight line to more or less match.
Most any mandrel type of cutter could do the straight angle by tipping the cutting bit but a purpose ground bit would need to be made to get the radius. Easier to do it with Al's method unless you were doing a ton of them. Particularly when you would sand it anyway after mandrel cutting so to even up chatter marks that sometimes happen with that method.
