NSP2. Cuz PA WiFi sucks
Status
Not open for further replies.
4:19 AM
Good evening OPE hope everyone had a great day today :borra2:View attachment 248575
lol wake up juice lol
hows you todd
Mine too, though my covers look like chit nowadays. Shoulders are gone. Used to be able to make a nice stack of nickles and make an over under weave. Now it looks like a stack of loose change, or maybe a drunk dirt dauber nest.
On angle, I like about 10 degrees up. Slightly pushing up from horizontal.
I dont do non ferrous.
If I cant weld it with a 7018, its not gonna happen.
ive gotten so i use one hand to brace and weld one handed even on overhead
im qualified in carbon and stainless plate and tube and inconel attachments i was dumb and passed that one
can only use about 3 inches of rod and may get 1 inch of weld per rod
forget about restarting a used rod
4:19 AM
I was in the lift basket with one of our guys years ago welding overhead. He had on leathers, but a sparkly got down the collar and ended up somewhere close to his belly button. Was pretty funny listening to him yell Owwww! Louder and longer the farther he wiggled it down. To his credit, he never broke arc the whole time.
lol its gotta be in a special spot for me to break arc
DuratecMan10
4:19 AM
Florida
Now I'm a WV fan. @dall
DuratecMan10
4:19 AM
Florida
Gimme the one on the right... I'm ready for a night of fun!
Dream
4:19 AM
Elberton, GA
What pisses me off is being on a good run with the cover, and sticking a rod on a booger you didnt see when you ran the root pass. All happy and in a good swing, then it just stops... Ok, I probably run too close. I just get it burning good and bury it.
DuratecMan10
4:19 AM
Florida
Wrong answer. One in the middle will HURT you, but you'll enjoy it!
I'm up for the challenge. Gimme all three!!! I'm made of steel and can last a few rounds...
4:19 AM
this last job we had to run 309 because of running duracore i probably went through about 100 pounds during the job
im sure you know what duracore is
chemical and abrasive resistant wear plate
Lightning Performance
4:19 AM
East of Philly
I call it "fearless with extreme caution".
Hesitation gets you in more trouble than doing what you know you are capable of. Just make sure you don't skip the steps you need to take to have a backup and a safety.
Sounds like you did everything right. Used your equipment as it was meant to be. Human error is unavoidable sometimes. Thats why people came up with the safety stuff. Just know what works, and what is overkill.
Hesitation to jump gets you stung. Be ready and check the tree with field glasses mid day before you do those big dead ones. That helps ;) Jumping off sucks.
Overkill is fine. It's all fun till you smash into the trunk like Woodpecker said. I did, once.
Now days if I absolutely must limb walk I don't. I've been out on the bottom of the limb and back many times. If there is nothing above it you have no choice. Not a good spot to be in but doable. If I have high point to rig off I go out horizontal on a pulley up top and back to my bridge. It's sweet with the lanyard on the limb to do canopy reductions. I have two rope grabs right rope grab is a stainless steel 1/2" lanyard and a piston grip 5/8" braid on the left. The bridge mounted T pin rope grab is on a rolling Williams D. Just tie off the tail to your bridge with a knot. It has loops on the outside to your use a beaner to set your pitch if you like. Out you go with or without gaffs on. Don't matter much but faster with gaffs.
Being a mod is dangerous bidness.
Worse than being a climber.
I kicked ass today and the weather kicked mine. The worst was the last climb to top a triple busted and cracked but alive sctetchy pine tree about sixty foot. Dog legs didn't cover it x3. What a mess so it got smashed it to the tree next to it an bit bigger and straight with one big limb almost a Y like spot. Let whole top roll off. Then clobbering the stick and bucking it with the 084 HD with a muffler mod. The piston is minty and no broken parts :) it sucked using it today in the heat but it ran good. 36 RS full round, drags at 0.045, first sharpen @20* top plate and 55. She digs hard and will stick the chain in under 24" wood. It needs ported and sold. Got one more ready and a second coming along. Porting the almost new top end and tossing it back on the busted spike mount case. It's a real nice short block to mill with. Adding a header pipe with a muffler. The mufflers huge for this Wildthang :cheer:. They all have very nice OEM everything inside. One has an oil pump problem. It appears stuck and spun the gear at the pump is my guess. No time right now to mess with it. Needs an 088 drum update so I got that and need the gear, new or used with the spring for 088. The plastics suck on the ones I'm keeping. The other saw is HD all original and pretty decent. It runs perfect. Starts on one pull from the first one of the day. All of them have new decomps and two have holes in the top cover, oh well.
Status
