John Wargo
9:51 AM
Pittsburgh PA
I worked on my shed roof all weekend. Cut gloves were an afterthought. Metal roof valleys are basically one giant fukkin razor blade. Luckily we have a good supply of band aids.
Did you run a separate piece of valley metal first then roof panels lay on top of that?
beaglebriar
The Peanut Gallery
9:51 AM
Warren Center, PA
Yep. W valley. The worst part was tying it together at the peak. I got it sealed up but it was a challenge. I know the cap will cover but I wanted it as nice as I could get it. Pretty happy with the end result but what a mfer!
sawmikaze
9:51 AM
steeltown
I never did a metal roof like that but shingled 100s. The valleys are always tough at the top.
Kiwioilboiler
346 Pic Examiner
2:51 AM
Marsden Pt, NZ
Pouring a pad??
Yeah 4 inches in your measures thick with reo mesh.👀
I need a bit more gap20 gravel first.
Shed kitset people are a bit confused because my crete guy wants to put water shedding rebates at the door positions and no one's ever asked about doing that before, but we'll work it out.
beaglebriar
The Peanut Gallery
9:51 AM
Warren Center, PA
I’ve done a fair amount of metal roofing but far from an expert. A guy that does it everyday would laugh at how long this took me.
beaglebriar
The Peanut Gallery
9:51 AM
Warren Center, PA
4 inches makes way more sense than 101.6 mm 😂. The taper or rebate at your doorways is definitely worth while but most people don’t think of it til they have a water problem.
Kiwioilboiler
346 Pic Examiner
2:51 AM
Marsden Pt, NZ
Just having the same talk with Dallas. He's like why are the studs 23 5/8 apart?
Because that's 600mm you dumb kunt. And 600 is easy to multiply.
Kiwioilboiler
346 Pic Examiner
2:51 AM
Marsden Pt, NZ
The cladding extends down past the outside edge of the slab by 3/4 inch so water drips off.
But now I'll need some ride on mower ramp trickery to get the doors to swing over that.
