Only the Tony
9:17 AM
Happy Thanksgiving guys!
Question for you guys who have animals...
As I sit and watch for deer, but see none, I've been thinking of how after a number of years the deer punched holes through the rubber liner in the water holes I dug.
I'm thinking of simply replacing with stock tanks.
Is one better than the other as far as galvanized, structural foam (rubbermade)Rubbermaid, etc?
I'd set them on concrete blocks and then just fill in the old water holes.
I'm looking at 250-300 gallon (ish).
How long are you going to keep water in them throughout the year? With your cold weather, if you don't drain or bury when you get to long freezing periods you will have to worry about splitting the sides. That said I have kept minnows in one in the yard and the ground contact has kept the last 6 inches from freezing solid until it warms up. We get about a week or two of negative mornings to teens afternoon, but no long, can't find your pecker because it retreated too far, stretches of cold.
I have had a 100 gallon rubbermaid tank for years. Never had a problem with it.
You don't have the weather that makes you want to move and question your sanity for living there from November to March.
Loony661
462’s 4-LIFE
9:17 AM
Winona County, MN
Ed, these are a big hit around here:
A buddy of mine is a dealer and installs them on people’s land all the time.
redline4
I'm huge in Japan
9:17 AM
Rosholt Wisconsin
Ideally through the end of November, but that won't always happen. Sometimes it's 40, sometimes it's 2 degrees.
Those look nice but that msrp kind of scares a simple oil changer from Wisconsin..
Lnk
Stock Chainsaws do not suck!
10:17 AM
East, TN
If you are going to bury something, I would get an ibc tote, cut it to suit. Refilling is going to be your problem. Do you have a way to run water or carry it to refill? Metal stock tanks are fine without ground contact, but pretty expensive compared to a tote. Just my $.02
redline4
I'm huge in Japan
9:17 AM
Rosholt Wisconsin
I have an IBC tote I put in the back of the truck for refills when needed.
This year was so dry and with the holes in the liner, I couldn't keep up.
I don't think I'll bury it. Just set something up on block to level it and be done.
Loony661
462’s 4-LIFE
9:17 AM
Winona County, MN
Gotta pay to play they say. I hear ya though, they certainly aren’t cheap. But they work. They hold water and do so more naturally than a tank above ground. You could easily work these into your existing pond sites with your skid steer to shape the ground accordingly.
