Normal Ring Blow-by?
Marshy
WFO Cutting
7:31 AM
Mexico NY
Just for kicks, let us know what you get for end gap on the new ring.
bwalker
7:31 AM
Montana
Wont yell you much unless you also measured the ring gap when the saw was new.
Regardless, I highly doubt this is a ring or cylinder wear issue. The piston doesn't appear to be worn.
Marshy
WFO Cutting
7:31 AM
Mexico NY
It might not seem like much but it will tell you if it is more or less than the ring that he plans on removing. If the new ring gap is 0.013" then hes not gaining much. If the new ring gap is 0.005" then it might be worth increasing.
redtractor
7:31 AM
Maryland
Remember, I didn't pull the jug because of a problem. Since I have it off, I'm changing it so I can run it another decade without worrying about it. I asked the original question as an opportunity to learn something.
bwalker
7:31 AM
Montana
Best guess is it was ran lean for an extended period of time. Piston wash or lack there of seems suggest this as well.
smokey7
7:31 AM
Detroit
The underside of the Piston shows that it got hot that's for sure. The Heat and may be magnified by poor quality oil.
old guy
Love me some Husqvarna
6:31 AM
Becker Minnesota
I just swapped a used 346oe p&c onto a 351, the old ring gap was .014, I read somebody say the most they would put back together was .013 so it got a new caber ring which was at .007 just above the ex. port.
With a base gasket delete and after one tank of fuel this one is blowing 170.
smokey7
7:31 AM
Detroit
When breaking in a new ring like that I prefer to bury the bar and push it to the point of almost stall in the clutch work it that way for a full tank of fuel.
bwalker
7:31 AM
Montana
You are making the assumption that the new rings will have the same clearance as the old ones. They very often do not. The other thing is I much prefer a looser vs tighter ring gap. If you touch the two end together while running it's game over.
bwalker
7:31 AM
Montana
You will never seat the rings until you load the motor. With a cast piston that's properly clearanced I bring them up to operating temp, then run the hell out of them.
Marshy
WFO Cutting
7:31 AM
Mexico NY
Do you hear yourself? Go re-read my post you quoted.
jake wells
no longer here
6:31 AM
ky
are caber rings just cast rings or are they chrome moly rings?
Marshy
WFO Cutting
7:31 AM
Mexico NY
They are cast iron
bwalker
7:31 AM
Montana
I believe I misunderstood where you were going with your post.
Iregardless that piston isn't worn too bad as the oil retention grooves are still present, and the owner claims the cylinder still has cross hatch. Given these two items I woukd use some GM top engine cleaner to remove the carbon, slap a new Husky ring in it, set the carb properly and run it at 32:1 on good oil.
