BigRed96
- 7:10 PM
- May 22, 2016
- New Richmond, Oh.
Good Day All, I’m new to porting. I just finished porting my first saw, a Husqvarna 55. I’m very happy with the results as far as my work goes. I just did the intake and exhaust and didn’t touch the transfers. Squish on that saw without the gasket came in at .030”.
I’ve moved on to my next saw which is a Husqvarna 51. I’m planning to build it for my Dad as a firewood saw. I set my degree wheel up to get the stock port numbers. I check the squish without a gasket prior to getting the numbers. I used .040” solder and it didn’t even touch it. I have to get some thicker solder to find out what it actually is. I bought this saw blown up years ago. First saw I ever played with. Cleaned up the cylinder and put a Meteor Piston in it. I never even broke the saw in. It has sat on the shelf ever since. With a base gasket the saw blew 150 or 160 iirc. So, do I go through the trouble of cutting the cylinder down to drop the squish or should I just move on and port it? I don’t want really high compression as my Dad’s getting older and doesn’t need to tear his shoulder up trying to start a saw.
Btw the stock timing number are as follows:
Exhaust 106* atdc
Transfers 135* btdc
Intake 70* btdc
Exhaust 106* atdc
Transfers 135* btdc
Intake 70* btdc
