decableguy2000
Working on a 036 for a friend that paid to much for a dead saw, scored piston. Cleaned the cylinder up, new OEM piston and rings, base gasket, and crank seals. Would not hold vacuum before tear down. Hols pressure and vacuum, will start and idle well, however when you hit the throttle it dies. I went through the carburetor installed a complete kit, new fuel line and filter all OEM. Saw did the same thing before and after the carburetor kit.
Jeremy
Jeremy
