Need advice on spark plug repair kit to buy?
Mattyo
Youtube speciawist
10:12 PM
Farmington, CT
Sorry....was just asking for a pic of the tap running into the roof
Lone Wolf
10:12 PM
Nj
Well I was only able to get the 14 mm part in and no threads of the 17mm part of the tap .
Lone Wolf
10:12 PM
Nj
I'm thinking if i mess with it it will not be perfectly square and not seal I want to maybe get Twinstaged to do it on a machine.
GoBigBlue1984
Bluegrass Fart Knocker...
10:12 PM
Kentucky
Shouldn't be a big deal. Making your own threaded insert would be even better if you're worried about it sealing. You can cut your threads to whatever depth you need and add some loctite on top of that and voila. It will not leak.
GoBigBlue1984
10:12 PM
Kentucky
Literally would take half hour to turn out/thread an insert and drill/tap.
Just my opinion but that's what I would do if I were you.
Mattyo
Youtube speciawist
10:12 PM
Farmington, CT
Grind it grind it grind it :)
It looks identical to mine. It really doesn't take much grinding on the cylinder to get that tip be straight. Your call though. If twin can get her lined up right...that would be ideal.
Lone Wolf
10:12 PM
Nj
It is if you don't have a machine shop. I don't want to FUBAR it up its the only 200T cyl I have left. Its half shot already.
Lightning Performance
10:12 PM
East of Philly
Exact same kit? Now we need an opinion on the combustion chamber you ground. Tomorrow I will try what you did on a junker.
He didn't remove enough to add up to much. Pull the gasket. Should be fine. Those saws run at high R's low volume and relatively low compression. Just be mindful of the plug to piston gap. I usually index my plugs to get the best burn. You can take less material out than Matt did.
twinstaged
10:12 PM
Ohio
Well just let me know. No pressure either way. Glad to see you want to make sure it's done right since I own one of your saws lol.
twinstaged
10:12 PM
Ohio
I wouldn't build another aligning arbor like that, but I was in a hurry and didn't have the right size die. I can't metric single point thread until I build the transponding gear for my Hendey. The OEM brand sleeve repair kits are so/so. Not a fan of the tap to sleeve clearance so I used the high temp thread locker to be safe.
10:12 PM
Any out come? I'm getting a MS 460 with stripped spark plug in today.
Any advice on the best fix would be appreciated.
Mattyo
Youtube speciawist
10:12 PM
Farmington, CT
Mike, send me the jug, I can put an insert in...
