- 4:27 AM
- Dec 30, 2015
- Brewster, NY
and it is (More Important) to NOT have one (longer cutter) than it is have one (shorter cutter); BEST to have ALL same length, but one LC will leave the extra grooves that mess up the finish; after sharpening, check the depth gagesBe careful as it is addicting. Common mistake, that i too made. In reality one should start with a 16" pine for the first milling victim.
File that chain and finish the log!
So, when are you gonna deliver that new present to me??? I think I also need a larger trailer and tow vehicle to get it to the site, but I'm sure it would be nice to have! Right now, I'm moving things the old fashion way, with timeberjack & pry bars!
Did some more this morning, I believe this was Pig Nut Hickory. Made 4 boards 7' long and 13-14" wide (2" thick) before lunch. I plan to turn the short piece (in the back of pic #3) into 4" X 4" for legs. Looks like I will also get one more good piece out of this log.
Although it went well, I don't want to mill any hardwood thicker than 14" unless I get a bigger saw. I may try to stay under 12" thick in the future unless I need it for a special project.
Spend some time with this part of the job. I milled a bunch of apple trees last fall. I didn't get the proper weight on them and they twisted and bowed like crazy. Well, 75% of them did. I spent a lot of time and hard work millin' them only to look at a mess now. Check out this thread - http://firewoodhoardersclub.com/forums/threads/drying-slabs.19650/#post-527111 Attention to detail here can yield much nicer lumber later and is well worth the hassle.Thanks.
Would you ratchet the boards down, or is it OK to just stack them with some weight on them (have separators between them)?
So is that cranberry juice in the pic for you or the saw![]()
Since a lot of apple tree is limbs versus trunk, I would imagine much, much more prone to twisting from internal pressures. Example of (why) most mills do not mill limbs, only trunks.Spend some time with this part of the job. I milled a bunch of apple trees last fall. I didn't get the proper weight on them and they twisted and bowed like crazy. Well, 75% of them did. I spent a lot of time and hard work millin' them only to look at a mess now. Check out this thread - http://firewoodhoardersclub.com/forums/threads/drying-slabs.19650/#post-527111 Attention to detail here can yield much nicer lumber later and is well worth the hassle.
Yep. It was all free wood so I figured I'd try milling some bases. I think if properly weighted they would have been ok. Next time I'll know what it needs.
View attachment 28928 View attachment 28929
