Ford3000
I don’t like the heat the cat retains in the muffler,
So I drilled out the two tacks of weld holding the housing the cat is attached to,
I then cut the cat out and tidied up the hole this left.
All I want to do is make the the saw run a bit cooler, will the removal
of the cat play a big enough part in keeping the heat down,
I have no tools to cut the baffles just behind the outlet screen, so am hoping
I have done enough, I could do away with the complete section the cat was welded to,
but am afraid that would result in one hell of a noise increase.
Your advise is welcome, and thanks.
