MS661c bites the rubber?
tickbitintn
1:06 AM
middle tn
Got this in the other day...
No compression. Has under 10 hrs on it.
Piston scored all to heck cyl covered heavily with transfer.
Passed pressure/vac test.
Decomp had a very slight leak ( not a dual plug version! )
Bottom end had rubber bits in it...
Don't know where it came from.
Sent from my XT1254 using Tapatalk
Canadian farm boy
“Normal” people scare me.
2:06 AM
Ontario, Canada
Does the intake tube have bellows?
If it does there's supposed to be a what looks like a rubber flat washer inside of it. I believe it's there to prevent the intake tube from collapsing.
There was an updated intake tube that iirc was a bit stiffer rubber and didn't have any bellows.
Sorry, no pics.
tickbitintn
1:06 AM
middle tn
Got a minute to get a couple more pics..
Hard to see but the little chunks have a "seam" down the middle, if you zoom in on the upper left chunk sitting on the raised ring you can see it...
May have been one of those rubber ringy thingyz...
And a better pic of the plating damage in exh port.
Moparmyway
Its just a saw
2:06 AM
In a meeting
Those bits of black , are they hard, or soft and pliable ?
If they're hard, check the anti-spitback plastic thing that snaps into the air intake under the air filter
Pics of the intake and intake side of the piston ?
XP_Slinger
They’re Just Saws
2:06 AM
Central NY
If that's the only plating damage I would definitely do as Mike suggested and widen it. How bad are the grooves above the port?
