Evansaw
- 7:14 PM
- Nov 20, 2017
- Greece
Yah ... motomix is an Alkylate fuel which runs 99% cleaner than pump-gas ... lotta nasty fumes are emitted that aren’t very good for your health nor the environment when using pump-gas especially with ported saws ! It ain’t cheap but what price do you put on your health? I’ve also found the added benefit of increased compression using motomix and if carb is dialed in properly everything is clean as a whistle inside ... pricey - yes but I roll the cost into the job ... also it’s nice to pull a saw off the shelf and go cut as the fuel stays potent FAR longer than pump gas ... haven’t had to rebuild/replace a carb or fuel line(s) since I began using it ! I think a lot of people would be surprised at the quality (or lack thereof) coming out of the neighborhood pump ! Ymmv
I m very happy you confirmed my suspicions and thanks for your input
Living in a country where i must pray the Gas Station Owner woke up good and didn’t perform magic to downgrade fuel while i m paying almost 2€ per liter for 100 octane I believe Stihl Mix is the best thing available to planet earth.
Cutting woods at mountains where the Gas Station is like 45km away and staying there for a month plus is another advantage of Stihl Mix.
Also very stable for the morning cold or humid forest to the hotter noon and afternoon cuts.
Since not lucky to permanent live in US so I could try the options mentioned here, STIHL MOTOMIX is my choice
