Ms461 vs 576xp Fire dept saw
Homemade
12:35 PM
Wisconsin
My fire department is soon to be in the market for a new saw to do roof ventilation. Stihl offers the 461 rescue. It has a larger recoil handle, wrap handle, and muffler deflector, and a special bar cover used as a depth gauge. Husky doesn't sell a factory option such as Stihl does. You have to go threw a 3rd party vendor to get such a saw with the add ons.
My questions are this
1) have the bugs been worked out on the auto tune/mtronic carbs? Our saws can sit for a month minimum without running and up to a year before it gets a worked beyond a warm up run.
2) As volunteer fire dept budgets keep getting under funded, do any of you guys have a QUALITY used saw of either option this will give us years of service? I'm not entirely sold on the fact I need all the fire dept add on's so just a regular 460/1 or 576 PHO will do.
3) if we buy new, should we wait for the 462? Are there any improvements over the 461? Will the 461 now be reduced in price because the 462 is coming out?
We do have a new TS-420 and I would like to stay Stihl just for brand similarity, but we as a dept have no dealership loyalty or brand loyalty.
Chainsaw Jim
Con Artist LLC
9:35 AM
Springfield Oregon
461 all the way. It will literally cost twice as much for the husqvarna version done by tempest or whoever, but it's the Tempest Ventmaster fire rescue saw.
Are fire departments even permitted to buy used items? I thought they were only supposed to buy new.
Khntr85
12:35 PM
Indiana
The 461 is a standard carb.....
Need to find out which carb will perform the best in a smoky environment....
2000ssm6
12:35 PM
NC
We have the 461 and it has been fine, hasn't seen much use though other than training. Sure is fun cutting holes in a roof.
Our old vent saw is an husky 272 that had a conversion kit, I put a standard b&c on it for storm clean up.
Chainsaw Addict
GO HOOSIERS
12:35 PM
Indianapolis
Recommend looking a Cutters Edge. Basically a Jonsered 2171
Sent from my SM-N900P using Tapatalk
Or 2188. External heavy duty air filter. Set up for fire. Big D handle guard on front. Come with carbide bullet chain. Two on each Ladder Truck and Heavy Rescue. Used to have on every Engine. Can't say enough about these. The bullet chain cuts through steel garage doors
RoyM
9:35 AM
British Columbia
I watched a demonstration by ICS who do conversions. They would do Stihls but much preferred Husky/Jonsered, they found the air intake system much better as the filter would go longer before clogging up
Homemade
12:35 PM
Wisconsin
Not really concerned with chains at this time. We've never seen any problems with engines preforming in smoke. Usually if the smoke is thick enough to make a difference on performance, you can't see to make the cut safely. Air filter wise, the only problems I know of it the air filter freezing over from water spray and -3* weather.
We don't have a johnsred dealer near us (53011). I don't know much about them, aside from that they're a husqvarna twin.
stihl livin
Do the Dallas
11:35 AM
Upper Midwest
According to your location you should be able to contact @04ultra which I believe carries jonsered saw.
dustinwilt68
Wilt Built Work Saws
12:35 PM
Southwest PA
I thought rescue saws were not allowed to be mtronic or autotune, due to electric shock making them paper weights?
dustinwilt68
12:35 PM
Southwest PA
I know the 461 is carb and the 576 could be had either with or without autotune, the 462 is mtronic only supposedly.
Homemade
12:35 PM
Wisconsin
Is that a flashlight mount on the clutch cover?
Some do come with flashlight mounts. Some guys put there fire cam in there also.
