Michael Rupley
- 5:55 PM
- Jan 5, 2017
- Dayton Nevada.
So this is a 2015 model that was just brought in and you think the jet is suddenly suspect. Hummm??
The plug looks lean in the first pick, but he is saying it won’t hit 13500 rev limiter at one turn out, who knows what the tune was before he trimmed the tab, if it has the bigger jet it would need to be tuned differently that a small jet, would it not? Once the limiters are trimmed the jet makes a difference! I have seen a bunch of ms440 that once trimmed were 1/4 out or 1-1/2 turns based on jet size, same with ms660’s they had several different jets. So I believe it makes a difference on the final basis tune, if it had the big jet, he may only need to be 1/2 -1 turn out especially if it has the tiny stock single outlet.So this is a 2015 model that was just brought in and you think the jet is suddenly suspect. Hummm??
What makes you think it’s running rich? It should be hitting the rev limiter at 13.5k. If you turn the h screw to a 1/2 turn out dose it still hit 13.5k?I ran the saw today with the new coil, ran pretty much the same. It seems rich at no load and it will run up to 13,500 with the H needle all the way in, but then it seems to run out of fuel when you load it up in a cut.
New carb on order. If I don't end up needing it for this saw I'll use it on another at some point.
That carb has the circuit where 80%ish of the fuel goes through the main jet and 20% goes through the H screw. It'll probably run like that for awhile...although it might be pretty leanPressure test that carb.
If you can bury the H circuit needle with no RPM change, it’s getting fuel from somewhere else...... leaking Welch plug mayhaps
My sorryThat carb has the circuit where 80%ish of the fuel goes through the main jet and 20% goes through the H screw. Itll probably run like that for awhile...
Even if the lever is adjusted correctly, if that metering spring is bad, that could be it.
