Wonkydonkey
Plastic member
- 1:04 PM
- May 14, 2017
- Sussex, UK.
I'm sure all those that have ported there 461 and changed the coil to an unlimited one, have them lying around.. from a thread not so long ago it was said you could use almost any coil from a stihl, it’s weather the lead is to long or short.. I bet mastermind has a few old 461 coils.
All I can think of, it fat as hell, the spark screen is blocked, I hope you have tried a used known good working spark plug, maybe check the flywheel gap to the coil...oh and try to clean the coil around the earth wire, it could be oily sawdust earthing it a bit, maybe worth a try without the earth wire connected, that would eliminate a weak earthing of the kill/stop switch...
Anyhow get a vid, when you next try it..
