MS461 help please
cookies
8:04 AM
ImAPotato
installing the gasket and impulse diaphragm backwards will make these HD carbs pump tons of fuel to the point even with the H needle only cracked will bog the saw from fuel. With the H all the way in he saw still runs and revs out. I just went through one driving me nuts! I caused my own delima rebuilding the carb I installed the kits parts just the way they came out and the previous person got them backwards causing the original running issue...they also installed the piston backwards so I should have suspected anything and everything after finding the little gem. I'm curious what using a unlimited coil will result in the free rev rpm being set at using the carb?
EFSM
7:04 AM
Extreme southern IL
BTW this is an old thread. As far as rpm’s with unlimited coil: after modding a saw, I find a tach to be almost useless. Set them by ear, and if you’re scared set em plenty rich.
cookies
8:04 AM
ImAPotato
I know it is a old thread, I had the same over fueling issue/symptoms and found the issue/solution and decided to share it on the appropriate thread so others might benefit. Threads never truly die unless a mod/admin shuts off posting. I've seen threads span 15 years building information, experiences, part numbers, part swaps etc getting better over time. Yes I tune by ear as well but a flat number to shoot for at the start saves time during final tuning.
