- 10:07 AM
- Dec 31, 2015
- East Jordan, MI
New carb kit came in today. Report back tomorrow.....
Gas? Again?
Yeah, but not to intentionally allow more fuel through a pump diaphragm. The one in the 261 is plastic. For $7, I'll find out if the brown one works better. I'm doubtful, but it can't hurt to try itHave you experimented with other saw carbs and diaphragms? Curious to read your findings.
What?
This and if the saw has some time on it already it's not unthinkable that the metering diaphragm isn't flexible enough either.
Tillotson for example recommends for high performance applications a gasket and diaphragm set after one years use and a complete rebuild after the second year to keep the carburetor performing properly.
The dieseling sound coming out of the long cut sounds like a "low needle is lean issue". My 385 is like that sometimes on a long, hard cut but I don't worry and like the zippy transition I have with low where its at.Changed nothing except mix to VP Racing 92 octane and Saber at 42:1. Saw felt like it would do same, but it compensated.
Sorry for long video, I wanted it to happen again, but it didn’t.
Saw still shuddered after coming out of the cut.
AND I'll bring my saws so I can cut some wood along the way. Leave your saws on the shelves so they don't get dirty.
True, and it wouldn't hurt. But bear in mind when they say 'high performance' that Tillotson do a lot of stff like this:
This one was NIB when I got itThis and if the saw has some time on it already it's not unthinkable that the metering diaphragm isn't flexible enough either.
This coming from someone who won’t cut in the rain for fear his saws will get wet.
Oh, the irony... Lol.
And as I further catch up on the thread the problem is solved with squish. Awesome.
Also some good derails on shots of 2 cycle oil etc. The movie "over the top" with sly Stallone one of the competitors wacks down a quart of motor oil to psych himself up and mess with his opppnent... LOL.
Sent from my XT1585 using Tapatalk
