tree monkey
- 10:28 AM
- Dec 14, 2015
- wi
Thanks. That is an excellent explanation Scott. Also the longest post I’ve ever seen you make, lol.
Never thought a lot about the Stoich difference. That is certainly interesting to me.
I know one good builder here speaks of “equalizing the stratos” and builds a mean ass 562. I believe that’s where many of the questions emanate from.
My question is why not try to use them, even with the understanding that they are a fresh air pump. Seems like air flow is the rate limiting step in power production. The carb usually can supply all the fuel ever needed.
yes and no, it depends on what can be done to the intake as a whole, intake and strato port combined. not gutted, but the combined volume of each. the only function of the intake is to fill the case. the faster we fill the case the faster the engine runs. but we need to empty the case as well, the shorter the intake dur the better we can empty the case. in other words move more air. this is why I want the dur to be about the same for each. if we can increase air flow before the port window, then it should be done. but we are limited buy what can be done to a rubber manifold and keep it reliable.
